Early Bronco Charts
oldy1978
New England
Hi new member here and first post. I figured I would start by offering the community something. I typed up some of the data for the early Broncos from the out of print Chilton Book into a few spreadsheets, I hope they are useful but be mindful of errors I am not the best at data entry.
Enjoy and happy holidays.
Oldy
http://classicbroncos.com/photos/data/7279/BroncoTuneUpSpecs.jpg
http://classicbroncos.com/photos/data/7279/BroncoFluidCapacities.jpg
http://classicbroncos.com/photos/data/7279/BroncoGeneralEngineSpecs.jpg
And here are the same charts in PDF format if you prefer:
http://classicbroncos.com/tech/BroncoTuneUpSpecs.pdf
http://classicbroncos.com/tech/BroncoFluidCapacities.pdf
http://classicbroncos.com/tech/BroncoGeneralEngineSpecs.pdf
Bronco Biff
Excellent data entry!! Checked out your garage also. Need some more pics of those fine steads!! The white one looks like it might have a good resume for pushing some snow!! Welcome aboard!!
NGABronco
N. GA now South Carolina
Welcome aboard!!! And thanks for the chart work, good info!!!;D;D;D
You need to join up with the "BONES" group!!! A great bunch of guys, they do several get-to-gethers and most are on here!!!;D;D;D
panalukes
Virginia Beach, VA
I always found those numbers interesting. I have a 77 with 134 stock horsepower. wooohooo! I wonder why it dropped down so much from 205 in the early 70's. Is it just a numbers game or did the emissions crap really lessen the Horsies.
miikee73
Shadetree Guru
Aloha
Emissions ,notice cyl volume increased along with HP decline,less compression.
It was both. As was mentioned, the lean mixtures and odd ignition timing and funky things they were literally experimenting with, did make a difference.
But the largest initial difference (between '71 and '72) was due to them using a completely new method for rating the HP numbers for consistency between all the manufacturers.
In simple terms, they went from GROSS power to NET power in '72.
And of course, as compression ratios dropped, cam profiles got lamer and mixtures got even leaner while they were hunting for that magic combination of numbers that would lower certain emissions, things just kept dropping and dropping.
The upward curve finally started taking shape in the mid to late eighties, when things started getting figured out and compression kept coming up and electronics kept getting more sophisticated. Unfortunately, we just got caught in the middle while they were trying to figure it all out.
Cars tended to get things sooner than trucks, and some cars better than others (think Corvettes, Mustangs and Cadillacs for instance) until we got back up into the old arena, and then above and beyond.
We might bemoan the loss of '69 L88's, '70 LS6's, Cammers, SOHC'rs and Boss', but anytime you can run a 13:1 compression, 600 hp engine on pump gas, have it lug right on up from idle to 6500 rpm without so much as a burp or cough, and get 30 mpg while doing it. I think things have come back with a vengeance!
Luckily we can put some of that knowledge in our old rides and still have them pass smog tests where needed, and run like the clocks we always thought they were.;D
So let's put a pumped up Explorer motor in that '77 of yours and take it racing!
fatboy
Glad to be here.
New Hampshire
Yes very cool charts, thanks for the info. As for the Bones group, New England is pretty big but we have a lot of active members all over.
Jeff10
Indianapolis
Hi Oldy,
Welcome to the forum. As others have said, great post!
I was wondering if you'd like to share the information in whatever file format you created. I'm always looking for useful information to save.
I can PM you my email address if you're interested.
Thanks,
Jeff
