Faster Eddie
Shipped on your dime.
Weiand 8011 Intake Manifold $75
Bronco Sport Eblems (set of 2) one is missing 2 pins but works well $30
3 grommets and bearings for 77 auto column $10 each
Column clamp 77 auto column $10
Turn Signal switch 77 auto column $15
Heater box, everything worked, just needs TLC on box $40
Exhaust manifolds off 302 $40
Valve covers off 302 $20
Heat collector for stock air cleaner $25
Stock steering wheel (2 cracks, no horn button) $25
Threaded oil dipstick for 302 pan $35
Air cleaner bracket $20
Arm rests (Black set of 2) $10
Window cranks (set of 2) $10
Tailgate hinges (set of 2) $10
Jack strap $10
Wiper motor bracket (stock 77 electric) $20
Front drive shaft (stock length) $25
Solid upper steering shaft '77 $25
New Parts:
14" Edelbrock Air Filter Drop Base $15
Fuel Filler Hose TBP for stock rear tank $15
(1) Chrome valve cover $5
Lokar (Non threaded) transmission dip stick $35
Jack strap $10
New Parts:
