Door switches
Slowleak
Georgia
I have been searching for a simple "no drill" way of installing door switches. I got a couple of these normally closed momentary switches and mounted them next to the door hinge with trim tape.
I did have to trim the stem down a bit to get the right fit. I balled up some aluminum foil and closed the door on it to get a good measurement for trimming the stems. I will wire up a harness for them with an override switch so i can turn them off if the doors need to remain open.
http://guitarpedalparts.com/product/spst-momentary-pre-wired-soft-touch-foot-switch-nc/
romerdoug
I'm digging the, what look to be, leather door straps! Nice work on the switch too.
tirewater
San Francisco Bay Area
What does the switch control? A light?
Seems these days you'd expect those switches to be completely wireless. I imagine you could hook up a standard household door chime with a magnetic latch that could trigger a relay to turn on/off a light.
Slowleak
Slowleak
Georgia
The switches control the dome light in the wiper housing and two under dash courtesy lights. I did not research wireless options much since the switches are right by the dash. Wireless would be great for a cargo light. Thats my next step.......
