Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Tech
Thread Tools
Old 02/26/16, 11:58 AM   #1
norm02
norm02's Avatar
Oil bath air filter service and restoration questions
Hey guys,
I'm planning on cleaning up the air filter assembly this weekend and I wanted to see if anyone knows how to either service the filter or what the correct replacement filter is. Additionally, I'm planning on sanding down the brackets and the filter housing and wanted to see what would the best paint to use when I go to respray it.
Thanks!
1966 Bronco Roadster Springtime Yellow, numbers matching with original drivetrain (170ci 6cylinder)
norm02 is offline   Reply With Quote
Old 02/26/16, 12:08 PM   #2
tortoiseracer
Tempe
oil bath fun
What I have always done is to clean the mesh with gas or white gas. Rinse it until it rinses clean. Sit it in the sun and let it drain. When it is dry put it back in the oil bath. I usually clean out the oil pan the same way. I sometimes pour a little oil over the mesh before I put it back in the oil bath. Just let the excess run back into the pan. I think there is a fill line mark on the pan if I am remembering correctly. I usually use whatever I am using during the oil change at the time.
As far as paint. The only real luck I have is a catalyzed auto paint as the rattle can stuff over time comes off during the cleaning process.
Always a mess but soooooooo much fun.
Chris
tortoiseracer is offline   Reply With Quote
Old 02/26/16, 02:11 PM   #3
norm02
norm02's Avatar
Chris
Ok, so all that has to be done to the filter element is just clean it out? I haven't had mine apart so I wasn't sure if it had a replaceable filter or if it's one that is serviceable. Thanks!
Old 02/26/16, 02:26 PM   #4
markw
Several to be restored EBs, mostly 66 year models. 66 frame, 68 frame, 71 tub.
Chico
Just don't do it in the garage next to the water heater.....
markw is offline   Reply With Quote
Old 02/26/16, 02:46 PM   #5
tortoiseracer
Tempe
Yes, just clean it out. The dirt sticks to the oil that sticks to the filter material.The material looks like aspen cooler pad material to me. Its not packed in tight and don't disturb it or it might fall apart.
Chris
Old 02/26/16, 03:18 PM   #6
Beer and Fish
Beer and Fish's Avatar
Peanut Island
It does not come apart, the actual element part of it...
Beer and Fish is online now   Reply With Quote
Old 02/29/16, 09:42 AM   #7
norm02
norm02's Avatar
Chris
Took it all apart yesterday and drained the dirty oil out. I cleaned the bowl, (not sure of the technical name but its what the oil sits in) and lightly sanded the inside of it to remove some rust that had developed. I do want to make sure that I'm understanding everyone correctly when they say to just spray carb cleaner onto the element.
I'm not sure if the filter cannister (again not sure of the technical name) assembly can be taken apart more than I have, but it doesn't seem like there's an easy way to give the element a thorough cleaning other than spraying it down while the filter is still inside the canister. Thoughts?
Old 03/03/16, 03:29 PM   #8
tortoiseracer
Tempe
Oil Bath Time Again
Yes, just leave the element intact. I don't care to use the spray carb cleaner as it seems to break down the material over time but hey, use what you want. Just be gentle with it as its 50 years old aspen wood. Just think, 50 year old swamp cooler, bwhaaaaaaaaaaaaaa
Chris
Thread Tools
Page generated in 0.34152 seconds with 58 queries
