- Nov 3, 2013
- 1,180
I apologize in advance for the long post. I'm just trying to be thorough with the details.
Rig has a 351W based motor installed with WH Extreme Duty Motor Mounts, C4, Atlas with HD short output and cable shifters. Duff Long Arms and 3.5" lift with coils in the rear (4.25° built-in caster). 4° bushings for a total of 8.25° caster. Rig is mainly driven hard on the sand. Not much street use other than short trips.
I had everything mocked-up this morning and just prior to tear-down I wanted to check drive shafts for binding while cycling the suspension without springs. Also wanted to measure for limiting straps. Rear went great no binding at 18.75" between frame and top of axle. Didn't take any pics after installing the shaft (needs shortened even with the short output shaft, though). Will be ordering new shafts with full splines.
Front I ran into a couple issues. First, I had the transfer clocked up to almost touching the frame. Actually had to remove the Long Arm bolts to get it clocked where I had it. I clocked it at this angle (third hole of four on the clocking ring) to clear the cable shifter assy that mounts on the transfer case. Here's a pic showing the shifter mount and how nicely it fits at this angle.
Installed the shaft to check for binding and it will not really even fit at this angle with 13.25" between frame and top of axle. That's only around 2.75" of droop from ride height (7" + 3.5" = 10.5" at ride height). I still have something like 3.25" more droop left in the shocks. I noticed while working on this problem that my rear output angles down and the front angles up. So I installed my new WH transfer case bushings that were around 5/16" taller than the ones I had installed and this is not enough to make the output shafts be plumb. Is it possible this angle is because the WH motor mounts put the engine slightly higher (around 1")?
So I clocked the transfer case down to position #1 to try to give the front shaft relief and my cable shifter mount interferes with the crossmember. I would have to go back to position #3 to clear the crossmember with the cable shifter mount like it was but that complicates the front driveshaft angle issue.
This pic is of the front shaft binding with 13.25" between frame and top of axle. Looks like I don't have much down travel. I can't install the shaft as it's too short.
This pic shows how the cable shifter mount (not installed) will interfere with the crossmember (yes I will un-modify it).
A few questions.
I'm feeling the pressure as I need to keep moving forward because I need to have it done before the first part of July for our annual trip to Silver Lake Sand Dunes. I pulled the body after January first of this year and everything has gone pretty well until today.
Thanks in advance.
Craig
A few questions.
Am I looking at something more than a magic shaft? I am running an engine with some power (415 hp/430-450 ft. pounds) and don't want anything to break.
Am I missing something that makes the transfer case lower than it should be compounding the front shaft problem?
What have others done with the crossmember interfering with the cable shifter mount? I did some searching and see where others have made a new crossmember mainly for four-speeds.
Thanks in advance.
Craig
