    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on. - Thanks!
SOLD 1966 Early Ford Bronco Restomod
Status
Not open for further replies.
xcntrk
NOVA
(Fully restored with modern modifications)
First year of the original Ford Bronco fully restored and nicely modified with modern amenities resulting in a reliable and highly capable classic 4x4.
Everything on this rig is new, rebuilt, or reconditioned. Full all steel body and frame restoration. All new engine, drivetrain, suspension, brakes, wiring, electronics, and interior components.
This rig is both an award winning show-car and a realistic driver that’s built for superior off-road performance!
Daily driver friendly with dependable street performance from a fuel injected V8 with modern fuel delivery system and heavy-duty cooling coupled to a 5-speed manual transmission with OD. On-road handling is well behaved thanks to performance 2.5” suspension, Bilstein shocks, 4-wheel disk brakes, and oversized sway-bar. Traction is managed via mechanical limited-slip in the heavy-duty rear axle turning 33x12.5 BFG mud tires.
Superior off-road performance is thanks to heavy-duty front & rear solid axles built with the best components, 4.10 gearing, front selectable differential locker, twin-stick transfer case with crawler gear-set, 6-point custom roll cage tied into the frame, custom rocker panel protection & side-steps, extreme duty driveshafts, heavy-duty rock proof steering links, 3-point front & rear seat-belts, 9.5k pound stealth front winch and rear tow-hitch/recovery point.
View the current for sale picture album HERE!!!
View original restoration picture album HERE.
VIN matching Virginia state title. Regional enclosed trailer delivery options available (at buyers expense). Willing to work with Nationwide shipping arrangements organized by the buyer.
Asking $30k
xcntrk
xcntrk
NOVA
Specifications
Engine:
  • Built Ford 302
  • Mustang 5.0 fuel injection conversion
  • GT40 lower, Explorer upper, 19lb injectors
  • Explorer serpentine front-dress
  • 4G 130-amp alternator
  • FlowKooler water pump
  • Saginaw power steering pump
  • Derale steering cooler
  • Hot Forged performance distributor
  • Screamin Demon coil
  • Livewire plug wires
  • Long-tube headers with W/B port
  • 2-into-1 Magnaflow exhaust
  • Ron Davis aluminum radiator
  • Derale 2400cfm electric fan w/aluminum shroud
  • 23-gal EFI fuel tank with integrated pump
  • SS fuel hard-line kit (frame-rails) w/filter w/high-pressure fittings
  • EFI braided fuel lines with pressure gauge (engine bay)
  • Dual hi-flow catalytic convertors
  • Fuel tank vapor canister w/roll over valve
Drivetrain:
  • NV3550 5-speed transmission with OD. Advanced adapter installation kit.
  • Centerforce II clutch kit
  • Rebuilt Dana-20 transfer case with Teralow 3.15:1 gearset, WH extreme output shaft, and Twinstick kit.
  • Ford 9” rear axle with: Detroit TruTrac LSD, 31-spline chromo axle shafts, 4.10 Yukon gears and bearings, HD pinion guard.
  • Dana-44 front axle with: Eaton E-locker, 30-spline 4340 chromo axle shafts with Yukon Gold joints, Warn premium hubs, 4.10 Yukon gears and bearings, 3/8” HD diff-cover.
  • WH extreme duty front & rear driveshafts
Tires/Wheels/Brakes:
  • Power brakes with 4-wheel disk master cylinder, proportioning valve, all new hard & braided lines.
  • Front & rear disk brake kits with new calipers
  • 15x10 MT Classic III wheels
  • 33x12.5 BFG KM2 mud terrain tires (includes full-size matching spare tire/wheel)
Safety:
  • 6-point custom family roll-cage with frame tie-in. Includes floor bracing with seat mounts and 3-point seatbelts front & rear. A-pillar mounts through the dash to maximize interior cab space.
  • High back bucket seats (front), headrests all seats.
Electrical:
  • Painless Wiring 23-circuit chassis harness
  • Painless Wiring Ford EFI harness w/mustang ECU (A3M1), all new sensors
  • Painless Wiring F5 electric fan controller (w/in-cab bypass)
  • Moates QuarterHorse EFI tuning chip
  • Innovate LC-2 wide band AFR sensor
  • Optima Yellow Top AGM battery
  • 500A push button emergency battery disconnect
Suspension:
  • 2.5” WH rock-crawler front coil springs
  • 2.5” Deaver 11-leaf rear springs
  • Custom extended front & rear shock mounts
  • WH Progressive polyurethane bumpstops
  • Bilstein 7100 shocks w/remote reservoir
  • Bilstein steering stabilizer
  • Hellwig off-road front swaybar with endlink disconnect
  • Bullet Proof Steering system with 1.5” Rock Proof tie rod, and 1.375” Race Proof drag link and trac-bar. Includes Stage-II Extreme Duty Spherical Rod Ends.
Interior:
  • Bestop TrailMax II front buckets on low profile sliders
  • Bestop TrailMax II rear fold-n-tumble seat.
  • Tuffy locking stereo center console
  • Matching stock style tachometer with billet mount
  • Grant Collector’s Edition steering wheel
  • Kenwood marine receiver with w/SmartPhone interface
  • 4” polk audio front speaker pods
  • 6” polk audio rear speaker pods
  • Alpine 4-ch amplifier
  • Kicker hideaway compact 8” powered subwoofer
Exterior:
  • Dual motor electric wiper conversion.
  • LED turn/brake bulbs
  • Speaker LED headlights
  • Rigid Industries SRM Fog/Driving light
  • Custom “Stealth” winch tray w/recovery shackles
  • Smittybilt XRC 9.5 synthetic rope winch w/in-cab operation
  • Custom rear 2” hitch receiver with recovery shackle
  • OE style new chrome F&R bumpers
hyghlndr
Hockessin, Delaware
I have had the pleasure of riding in this one. It is an awesome Bronco with incredible attention to detail. Good luck with the sale.
xcntrk
xcntrk
NOVA
Thanks Eric. You should consider buying it yourself. I'll even install your bumper back on it before delivery ;D
broncosbybart
Love your rig. Trying to convince my lil' sister to get it. :)
I'm sure it will make whoever gets it very happy!
tasker
all knowing of nothing
NH
NOOOOO!! love this truck! can't wait to see it again in a couple weeks!!
ared77
Call/Text me sometime.
Norm
Winchester, Ky
cell 1-859-351-8702
marcussly27
If any other members have experience with this truck please let me know. I'm an interested first time Bronco buyer. Thank You! 269-254-4886, feel free to text me
xcntrk
xcntrk
NOVA
Attention all interested buyers.
The response and interest to this sale has been a bit overwhelming. I have received multiple offers thus far and I am considering each in the order it was received.
If you have posted in this thread, or sent me a private-message, I will get back to you as soon as time permits – one way or the other.
Thank you to all who have shown interest and made any offers thus far. Appreciate your time and patience.
White Knight
Bronco for sale
Are the seats re-upholstered or in the spice fabric option from bestop?
Status
