I have had 2 radiators and three hoses. I've done a lot of work on my bronco to try to get it cool.
I have the silicone radiator hoses now which I really love. However, they suffer from the same problem all others do (at least in my application) in that they all come in contact with or dangerously close to the fan blades. I added a 1" spacer to the fan, now it hits the shroud (dealing with that in another thread).
The only fix that I have found that works is to treacherously put the upper radiator hose on about 3/4" and tighten it up, essentially on top of the flared end.
A picture is below, but I am curious: When people run a puller fan (not that I want to go this route) can they/do they get away with not using a shroud? I guess I've seen most without a shroud, and the really big expensive systems usually have a shroud. I want to stay with this great 18" mechanical fan as it so far is working great and I would space it another 1/2 closer to the radiator I suppose but would need to replace the shroud, but that seems like a lot of work to get the radiator hose to just work.
I guess I could drain & remove the radiator and ask the radiator shop to extend the inlet side another inch. How else has this problem been solved? Surely I'm not the only one who has experienced this, and please...stop calling me Shirley.
