Skiddy
- Oct 8, 2003
- 11,564
I have Toms H4 headlight kit (harness, relay's). my stock 74 wires have been hacked some. I have two wires coming in to the head light one green, one red and ran brown to ground. I think I hooked them up like the original headlights were, except the two reds for the hot in the new harness.
here is the issue. I have bright or dim lights not sure which as not sure the bright indicator light is even working.
before changing the head lights, the bright and dim worked. just had the dreaded flicker once in a while. I have a new dimmer switch to put in, not even sure that is the problem though.
