Dashboard Pictures Requested
BRONCITIS74
I am just about ready to do the dash in my 74 Bronco. I want to add seperate gauges for oil pressure, water, volts, and fuel supply. I was wondering if any of you guys that have cool dashboards in your trucks would mind posting some pics of them. Thanks
Scoop
Have Bronco, Will Travel
Cuchara, CO
I just redid mine and added gauges and some switches. Mine's pretty simple and I've kept it more on the stock side. Some people have done some highly modified dashes that are really nice. But here's one on the simpler side.
nvrstuk
PNW
Great designs out there... real craftsmanship.
My .02, and I'm not trashing anybody's layout/design but I think it's really important to not HAVE TO look away to the middle of the dash or almost to the glove box to read a gauge... cool to have 6 gauges all lined up horizontally but I can guarantee that if you're doing some hard rally type wheeling you won't have time to look at them OR you missed a deep hole in the sand at the beach...
This takes your eyes off the road and you will be MUCH less likely to notice a needle isn't where it should be... just something to think about...
Miker
Here are some dash pics from my '76 copper rig. I was, and am still to this day, afraid to ask the guy that did it as part of my build how much it cost. I'm afraid I'd vomit in my mouth. But it came out pretty good I thought.
AZ73
Still in Progress but here's the plan and the rough finish. Switches and A/C controller will go where the paper is on the dash, and a push button start will be under the oil pressure gauge
trekgurl
went completely resto mod for mine,
(had somebody do it)not me. Aluminum dash, steering column will drop and dash pivots away from the firewall. It's still only phase 1 and needs phase 2 to be completed ( painting, vents, dash pad etc) but 9k miles on like this and I like it. Had to include pic of the 600 watt pig behind the seat.
1strodeo
Squirrel Watcher
Wisconsin
Man all those dashes look pretty dang cool! Mike, where did you get those windshield knobs?
1971lubr
Cape Coral, FL
Here is how I did mine, I wish I had put the speedo and tach above the 4 smaller gauges now.
bronconut73
Mine.
Sport Comp's in cups.
Still need tranny fluid temp. and engine oil temp.
sanndmann3
Here is mine. I put the important gauges (oil & temp) closer to the driver. Trans and volt are father away... gas and air pressure (onboard air) on the left.
904Bronco
San Martin, CA
And now for something completely different...
I am 6' 3" easier for me to glance up.
chriskent85
How did the radio fit with the vents behind it going to the dash?
