The Bolt "Thread"
callmemarsh
Firstly, sorry for the bad pun. I couldn't resist.
I am going to be putting in a fairly large order to get a bunch of assorted nuts/bolts to reassemble the 73. Going with BoltDepot.com Anybody have experience with them? I am open to suggestions too.
I have some specific nuts/bolts that I know I need, but need some clarification on sizes, grades, etc.
Also, I want to go ahead and get an assortment of misc hardware since I'll be paying shipping anyways. So please, let me know if there are certain sizes just to have on hand. (ie 10/12 mm for foreign cars).
Here is the current list (correct me if I'm wrong on sizes/pitch):
1. Lower shock mount (stainless or grade 8?): (4) 1/2" x 2 1/2" with washers/locking nut
2. Rear Frame>Shackle Mount (grade 8): (2) 9/16" x 5" with washers/locking nut
3. Trac Bar to Frame (grade 8): (1) 9/16" x 3" with washers/locking nut
4. Trac Bar to Axle: (1) 3/4" Castle Nut (fine thread?)
5. Trans X-Member (grade 8): (8) 1/2" x 2"
6. Steering box (grade 8): (4) 9/16" x 4 1/2" with washers/locking nuts
That's just a start. I haven't gotten a chance to go over the entire thing to make a comprehensive list, but that's what I'm hoping you guys can help me with!
charlie6976
Grand Coulee WA
Check the venders catalog/web sites. They have some good bolt packages you could buy or get ideas/information/sizes from. I know Jeff's Bronco Graveyard has a lot of different packages. On certain things you might want to upgrade to ARP (flywheel,...). Hope this helps.:)
I order my arp bolts through Summit.
C
callmemarsh
I've talked to/researched a few vendors in my travels and placed some fairly large orders. The problem is some of the kits I've received don't come with hardware. Not a problem though, I really just want to make up my own kit and order some extra to have on hand anyways!
I really just want to document what bolts go where and try to avoid any size/clearance issues people have had in the past.
bronkenn
Bronco Guy
Southeast Ohio
You might want to check out Albany County Fasteners. Very good site for getting bolts and if you enter code CARD10 you get 10% off. You can order any quantity and shipping is free after 35 bucks. That's a good deal in itself cause them bolts get heavy. I ordered some bolts from another company a while back and the bolts were 60 bucks but the shipping was 12 dollars. Ken
catfan
If you have a Rural King near you they have a large selection of all grade bolts and hard to beat the price.
(1. Lower shock mount (stainless or grade 8?): (4) 1/2" x 2 1/2" with washers/locking nut) If you use a 2 1/2 bolt you will have threads inside your shock bushing, use a 3" and ct a 1/2 off the end if you don't like it sticking out.
NicksTrix
have shopped bolt depot before. solid selection and reasonable pricing..there are a variety of deals out there, as mentioned. just have to decide what works for you.
you list a 9/16 bolts for your steering box. unless you've changed something they are 1/2 from the factory
C
callmemarsh
Some great info already!
Ken, Gonna check out Albany Fasteners for sure, sounds like a great deal.
catfan, that's the kind of info I need! 3" it is. I dont have a Rural King, but I am going to price out Fastenal. I don't know why I didn't think of them sooner.
NicksTrix, No, I didn't change anything on the steering box. I'm at work and took a guess at it haha.
ntsqd
heratic car camper
Upper SoKA
Keep in mind that generic stainless steel bolts are no stronger than SAE Grade 2 and may not be that strong. NFG for anything important.
Also know that using a SST nut on them is a recipe for a seized nut and/or galled threads. Anti-seize in the threads helps, but if they're on there for a while the anti-seize may not last.
If all you have in the shop are SAE Grade 8 bolts, then you or your helpers can never put a Grade 5 bolt in a place where it doesn't belong.
For Life Safety or "Mission Critical" bolts consider ARP or F911's.
fosgate150
See below... I had saved this from another person...
Location Qty. Size Type Notes
Motor Mounts 2 1/2 Flat Washer
T-Case Crossmember to Support Angles 2 1/2 Flat Washer
Fender Support Brace Rods 12 1/4 Flat Washer
Cage Mounts 24 3/8 Flat Washer
Hardtop (Bedrails) 14 5/16 Flat Washer Use on nut or 2 per if not integralcarrier
Hardtop (Windshield) 9 5/16 Flat Washer Use on nut or 2 per if not integral
Seats (Front) 6 5/16 Flat Washer Stock is integral with CS
Seats (Front) 3 5/16 Flat Washer Stock is integral with CS
Torque Convertor STK 16 3/8-24 Flanged Stover Nut
Track Bar Mount (66-75, Axle End) 1 3/4-16 Castle Nut
Heater Core 4 1/4-20 Nylock Nut (GRD 8)
Cage Mounts 24 3/8-16 Nylock Nut (GRD 8)
Hardtop (Bedrails) 14 5/16-18 Nylock Nut (GRD 8)
Hardtop (Windshield) 9 5/16-18 Nylock Nut (GRD 8)
Soft Top Header 9 5/16-18 Nylock Nut (GRD 8)
Body Mounts 8 7/16-14 Nylock Nut (GRD 8)
Front Bumper (Hanson) 4 1/2-13 Stover Nut
Motor Mounts 2 1/2-13 Stover Nut
T-Case Crossmember to Support Angles 2 1/2-13 Stover Nut
Coil Spring Upper Mount 2 3/8-16 Stover Nut
Leaf Spring Hangers 4 5/8-11 Stover Nut Flange nut prefered
Leaf Spring Hangers 2 9/16-12 Stover Nut
T-Case Bushing Mounts 2 9/16-12 Stover Nut Stock uses 9/16-18 Castle
Track Bar Mount (66-75, Frame End) 1 9/16-12 Stover Nut Stock uses 9/16-18 Castle
9" Third Member 10 3/8-24 Stover Nut
Radius Arm Nut 2 3/4-10 Stover Nut Stock is Castle
Body Clip Nut STK 50 5/16-18 Short throat
Leaf Spring Hangers 2 9/16 Flat Washer heavy duty
Rock Skis 20 5/16 SS AN Washer
Soft Top Bedrails 14 5/16 SS AN Washer
Soft Top Header 9 5/16 SS AN Washer
Fenders (rear edge) 2 5/16-18 x .7500 PHMS Phillips head
Door Striker Post 2 5/16-18 x .500 CSK Screw Phillips head
Tailgate Catches 4 5/16-18 x .750 CSK Screw Oval head Phillips
Tailgate Release Handle Bucket 4 1/4-20 x .500 CSK OHMS Phillips
T-Case Crossmember to Support Angles 2 1/2-13 x 1.500 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 1.250 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 6.000 GRD 8 CS
Tailgate / Liftgate Anti-Rattle Tab 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Tailgate Release Handle Bucket 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Fender Support Brace Rods 12 1/4-20 x .750 GRD 8 CS Stock with integral washers
Cage Mounts 24 3/8-16 x 1.000 GRD 8 CS
Coil Spring Upper Mount 4 3/8-16 x 1.000 GRD 8 CS
Coil Spring Lower Mount 2 3/8-16 x 1.250 GRD 8 CS
Pedal Assembly / Brake Booster Bracket 2 3/8-16 x 1.250 GRD 8 CS Stock with integral washers
Pedal Assembly / Brake Booster Bracket 5 3/8-16 x .750 GRD 8 CS Stock with integral washers
Tailgate Hinge Pivot 4 3/8-16 x .750 GRD 8 CS Stock with integral washers
T-Case Crossmember Support Angles 8 3/8-16 x .750 GRD 8 CS
Door Hinge Post 12 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Hood Hinge 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Seats (Front) 9 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Tailgate Latch 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Core Support to Grille 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Fenders 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop Corner Posts 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Steering Column Firewall Mount 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Dana 44 Cover 10 5/16-18 x .625 GRD 8 CS Stock is flange head
Leaf Spring Hangers 4 5/8-11 x 4.500 GRD 8 CS
Bellhousing to Engine (C4) 6 7/16-14 x 1.750 GRD 8 CS
Body Mount (Front Clip) 2 7/16-14 x 3.000 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Driver/Passenger) 2 7/16-14 x 3.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Behind Front Seats) 2 7/16-14 x 4.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Tailgate) 2 7/16-14 x 4.750 GRD 8 CS Stock is 3/8-18, add for body lift
Radius Arm Caps 8 9/16-12 x 2.500 GRD 8 CS
Track Bar Mount (66-75, Frame End) 1 9/16-12 x 3.000 GRD 8 CS Stock uses 9/16-18
T-Case Bushing Mounts 2 9/16-12 x 4.000 GRD 8 CS Stock uses 9/16-18
Rock Skis 20 5/16-18 x .750 SS BHCS
Soft Top Bedrails 14 5/16-18 x .750 SS BHCS
Soft Top Header 9 5/16-18 x .750 SS BHCS
License Plate Frame Bracket 7 10-24 x .375 CS Thread Cutting
Heater Core 4 1/4 Fender Washers 1.000 OD
Seats (Front) 5/16 Fender Washer
Steering Column Firewall Mount 3 5/16 Fender Washer 1.250 OD
T-Case Crossmember to Support Angles 2 1/2 Lock Washer
Coil Spring Lower Mount 2 3/8 Lock Washer
T-Case Crossmember Support Angles 8 3/8 Lock Washer
Bellhousing to Engine (C4) 6 7/16 Lock Washer
Radius Arm Caps 8 9/16 Lock Washer
Body Mounts 8 7/16 Fender Washer 1.500 OD
Hardtop (Bedrails) 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop (Windshield) 9 5/16-18 x .750 GRD 8 CS Stock with integral washers
Leaf Spring Hangers 2 9/16-12 x 4.000 GRD 8 CS Flange head prefered
Liftgate support arm lower mount 4 1/4-20 x PHMS Phillips head, thread cutting
Radius Arm Bushing Washers 4 1.000 Fender Washer 2.500 OD
Tailgate Support Linkage 8 5/16-18 x GRD 8 CS Stock with integral washers
Track Bar Mount (66-75, Axle End) 1 3/4 Fender Washer 2.375 OD
C
callmemarsh
fosgate150, just saw this list. Spot on, exactly what I needed!
Gonna get an order in today!
