KeithKinPhx
- Jan 8, 2017
- 444
I would like to install these in my 68.
http://www.keepitcleanwiring.com/ca...MBL/12-Inch-Stainless-Steel-Door-Loom-(1-Pair)
To do would require a 1/2" hole to be drilled straight thru my door pillars. Both sides. The wires would enter from the inner fender areas, pass thru the pillar and into the doors.
Has anyone seen this before? My sheet metal is solid and I would center the hole between the door hinges.
Any major issues? Should I reinforce the area by tach welding a washer around the new holes?
Yes I know it is crazy but I want a clean from the inside the tub way to get wires to my doors. I am installing nu-relics power windows and power door locks. May do the fiberglass door speaker insert from Bronco Hut as well.
Thanks.
Thanks.
