BwoncoHowie
C-4 Wizard
- Nov 11, 2002
- 3,571
Here all along I thought my steering box would be out and back in on Saturday. Just wasn't to be this time. Tore it all down and found that the Ford dealer sold me the wrong seal kit. (It's the saginaw 5 1/2 turns power steering box) I had no problem finding the correct seal kit, (NAPA came through again) yea!
But...when I took the pitman shaft out for cleaning and inspection purposes all those little needle bearings fell out of the housing, then I discovered the damage... The bearing is trash but the shaft is still good.
The trouble I'm having now is locating the bearings that support the Pitman shaft. One of the bearings is broken the other one looks fine. I will be replacing them both. It's Torrington part number BH-2020.
Has anyone else had trouble with finding replacement parts for these?
What did you do?
There's gotta be an easier way. GRRRR!
I'm into this thing so far for about 60.00 in parts, hope it will be worth it in the end. ~BH
What did you do?
