asabadin
Well, After Adjusting My Timing Getting A High Vulome Water Pump New Thermostat And Fan Shroud, Rebuilding My 4core Radiator, My Rig Was Still Running Hot At Slow Speeds Or While At Idle For A While . I Talked To Scott From American Bronco. He Told Me That His New Product Would Reduce The Engine Compartment Heat By At Least 10 Degrees. The Install Was On!! Headed Down His Way Last Saturday, Install Took Us About 2 Hours. Easy Install. I Elected To Paint Mine Flat Black(not Really The Bling Bling Type). You Cannot Even Tell They Are In Unless You Look Up Close!! Elected To Drill Some Extra Holes So I Can Remount My Inner Fenders I Cut Out For Cold Weather Or If I Ever Decide To Do Some Deep Mud Bogging. Ok, Ok On To The Results A+++++++!!!! My Engine Temp Would Hit 220 Degrees, It Has Not Been Over 190 Degrees Since The Install Even Under The Most Extreme Conditions!!!! Bumper To Bumper In 90 Degree Weather And A Steady 6 To 8 Mile Climb Over The Cajon Pass In About 8o Degree Weather In Traffic!!! Did Some Light Offroad Climbs But Ran At Low Rpms Undre Stress For About 1 Hour . Like I Said The Temp Never Went Over 190 Degrees!!!
