SaddleUp
This isn't my EB anymore however I still have a special interest in it because I gave it to my brother to make whatever he wanted out of it. This EB started life as a 70 and obviously wasn't taken of too well. From the condition it was in it appears that it has set out in the weather for the better part of 10 or more years. The last owner before me started to make a project out of it and had obtained a few items for it in an attempt to make it trail worthy before he pulled the front cover off the Dana 30 and found the carrier cracked in half and the gears wasted. Apparently he gave up at that point. (It didn't help that the frame behind the rear tires had holes in it) When I looked at it I saw enough stuff to make it worthwhile to pick up for the grand sum of $300 which I recently recouped from the sale of the 3 speed tranny and Dana 20 it had in it. I have made $120 or so off other parts as well and used the door inserts from it and several other misc. parts for mine. Once I picked it apart I offered to give my brother the frame and body if he wanted to make something from it. When we finally got the motor fired up it sounds strong enough that I am loaning it to him so part of it is still mine. (The motor is for sale though since he has another one to replace it some time after SOB is over, price to be determined after it is run at SOB) After I offered it to him it sat in my garage for about a year until about 4 weeks ago when he decided to get it ready for SOB. The plan essentially was to take the drivetrain out from under his 78 Bronco and put it under the 70. (He has 3/4 ton stuff to put back under the 78 as a tow rig) Most of the drivetrain has already been built up this year with the intention of using it under the 70. I.E. 35 spline spooled 9" and alloy axles in the front with an ARB air locker and 5.11 gears. These are driven by a C6 and NP 205. We have most of the EFI system to drop that on top of the motor however it is doubtful it will be on it before SOB. (Too many other things left to do) In the posts below I will walk through what has been done and then will update it with what we have remaining to do. I don't have any pics from the day he pulled it out of my driveway. The above condition pretty much describes it except that by the time he picked it up it was setting on jackstands and we had to stuff axles back in (one broken) and put the frontend back under it just to load it on the trailer.
