70EB
I recently completed my SEFI swap on a 351W (see thread in Bronco chat). I noticed that after the truck sits for a while, it takes two attempts to start it. First attempt it will start but then stall, second attempt it starts right away. Sounded like a fuel issue and this is what I found out.
Fuel pressure at idle is 34psi. If I remove the vacuum line from the regulator, it jumps up to 40psi. Once I shut the engine off, I left the pressure guage attached (to the schrader valve on the rail) and the pressure slowly bled down to below 20psi before I pulled the guage. I think it bleeds all the way down to 0 pressure if I let it sit long enough. This would cause the starting issue.
How can you tell if it is a regulator issue or a injector? All my injectors are firing (I can hear the clicking on each one when tested with a long metal rod).
I have the 96 Explorer fuel rails and 24lb injectors. Both were purchased used but where in very good shape and clean.
I am leaning toward the regulator being bad but wanted to get some opinions before I send the $$ on a new one. If I have to get a new one, would an adjustable be worth the money?
Thanks. Bill
Thanks. Bill
