powersteering
twbowhunter
anyone running powersteering on a i6? just wanted how it is working for you and any tips/problems? also how abought power brake boosters on the i6 good /bad ? i am getting ready to buy these parts for my sons project and would like any input thanks !%)
T
twbowhunter
i thought abought that but did not know if that would rob more power from the i6?
fordguy
broncoman in alabama is running hydro and i think p/s on a I6 check with him he will clue you in
Pa PITT
Stephenville TEXAS
WE just installed power steering on my running buddy 1966 I6 and it has worked great since he used a bronco gear box and a SAG pump ..It is one finger steering and we just got home from a hunting trip in New Mexico we put about 25 miles a day on it in 4x4 and in the rock and gullys not one problem ..so go for it ....It didnt seems to rob one drop of power from the six
fordguy
if it robs power get a lower gear most I6s have 4.11s
bmc69
The hydroboost systems do not add any additional load to the PS pump. H-boost is a parasitic pressure device only and uses practically zero flow..maybe an ounce or two of fluid for every push of the brake pedal.
66Gasgrill
Canton, NC
I have power steering on my I6. BCB's bracket, napa upgrade pump, and a converted 78-79 4x4 ps box. I run fullwidth axles and 37's with no problems. I like it. :)
Broncoman
I run power steering and hydroboost on my six.
I used a stock power steering box.
Hydroboost from a 93 Astro Van.
Saginaw dual return pump on the stock bracket that has new holes drilled in it.
Mount the original bracket on this bracket from BC Broncos
http://bcbroncos.com/store/product_info.php?cPath=37_82&products_id=332
For the adjuster I used the alternator bracket from a v8
I didn't notice a power loss with hydro boost. Do both now. You don't want to have to come back and re-engineer this later if you decide you want power brakes.
If I was you I would just run on of the after market saginaw brackets instead of trying to make an original work. Like this.
http://bcbroncos.com/store/product_info.php?cPath=37_82&products_id=655
Gummi Bear
This is good stuff guys, thanks a lot. I'm planning on the P/S and Hydroboost for my wifey's rig (a 170).
It's hers, and she makes all the decisions, but I'm not giving her the choice to not do these upgrades, they're going in no matter what. ;D
Broncoman
Sometimes you just got to put that foot down.;D
If you or anyone else needs help let me know.
FoMoCo
Ragland, AL
I helped broncoman with his hydroboost and disk brake conversion. It looks clean under the hood and has amazing stopping power. I drove it before and after and all i can say is, WOW! I will do the same set up on my bronco. ;D
Fairbanks, Alaska
power steering
I have a quick question on this. Where can you find the dual groove pulley for the I6? I would love to have power steering but, I have the single groove pulley. I can get the parts for the hydroboost and power steering but, no pulley. Somebody help!
69 Bronco
Aurora
I have P/S on my six. I used the parts from a junk yard 2x4 f150 (pump, box and all the hoses and a bracket from a Maverick or the like) I will get pics if you are interested. I've been running it for 10 years with no problems. I currently run 31 10.50's and a stupid small aftermarket steering wheel.
Broncoman
I got a my water pump and crank pulleys from a maverick at the pull-a-part.
The maverick used a water pump with a longer shaft so the pulley was deeper. This left me with two options: get a new water pump that fits a maverick or find some kind of spacer to put behind the pulley. As luck would have it I just happened to have a spacer I found(along with other misc auto parts) in the back of a 77 parts bronco I bought a few months earlier.
T
twbowhunter
so those of you running the power brake booster no problems with the 6cyl making the vaccum??:?
Gummi Bear
So long as it's a healthy motor, it should make plenty of vacuum. It doesn't take much to make the booster function.
Hydroboost is even better, if you search here, you'll find a goldmine of information on them here. With your new P/S setup, it's just a couple of hoses to make the hydroboost work for you.
Broncoman
Here are some pics of my setup for someone that was wondering. I modded a stock pump bracket and mounted to the BC Broncos bracket and used an alternator adjuster bracket from a v8 to adjust belt tension.
