Welllll, It seems like I'm the last person on CB to do this mod.
It's on my daily driver. If I like it, I'll do it to my trail rig.
I used a stock angled bracket that a friend powdercoated for me. A hydroboost unit off an excursion (Napa p/n: 52-7357), my stock master cylinder (front disks, rear drums), and Russell fittings and hoses with the following p/n's which differ slightly than other write-ups.
1: 11/16-18 to 6AN Summit p/n: AER FBM 2965 (for stock power steering box high pressure inlet)
1: 5/8-18 to 6AN Summit p/n: RUS-640380 (for Saginaw pump high pressure outlet)
1: 6AN to 16mm-1.5 Summit p/n: AER-FBM2608 (for Hboost high pressure outlet)
1: 6AN to 18mm-1.5 Summit p/n: AER-FBM 2608 (for Hboost high pressure inlet)
4: 6AN to 6AN 90 degree hose fittings Summit p/n: Rus-620421 (or you could use 6AN to 6AN 45 degree RUS-620411)
6' Russel Power flex hose Summit p/n: RUS-632610
I cut off the H-boost push rod and welded a threaded spacer on it and cut off a matching bolt so I could screw a yoke end that I got at the hardware store (thread is 3/8 - 24). It was a little long so I cut the spacer down, I also cut the spacer to facilitate a good weld.
