Ok so.... I have recently purchased an 87 bronco 4x4 that had the early oem tfi/eec wiring setup. The PO had hacked the wiring badly and after countless hours chasing wirea and replacing parts I decided to convert her to the DSII with a pertonix ignition coil and pickup module to eliminate the problematic efi system. And to the efi fans, don't bother proclaiming the vast superiority and efficiency of FI. In most cases yes, it is. But in the case of fords tfi system. I'd rather ANY alternate system after my experience. Dare I say, got mad enough at one point I nearly swore Fords off altogether. Anyways, back to the beast. Ive pulled a beautiful DSII harness today out of an 82 F-150, ordered the pertronix II ignitor and flamerhrower coil, and am ordering a vac advance dizzy next. My first 2 queations are... Can I use/modify the oem intake manifold to hold the holley 4 bbl I'll be using? I've heard of it being possible with minor modification. Second, if the efi intake cannot be used would a stock carb intake and a reducer be a viable setup for the 4bbl? Plenty more as I fo I imagine but for now...
