I tried Googling the internet for upwards of seven minutes and gave up knowing that you guys would just tell me the answer in 2 seconds
Yes with original bronco front dress and timing cover. U will need custom balancer to use bronco pulley and explorer imbalance. Also make sure the timing chain cam, gears. Pump eccentric and pin all play nice together. Spend the money on new parts here. 85 mustang GT was roller motor with fuel pump as a reference.
Dint forget to change dizzy gear for roller cam
You will need clutch pivot adapter id standard shift as later block does not have that.
You will need new flywheel or flex plate with explorer imbalance
You can use explorer aluminum pan but will need in block dipstick. Ford motorsport makes a in block tube and dipstick.
Remove oil filter adapter/cooler and buy new stud for standard FL1A filter.
I think that's it.. I would pull the heads and check them out new gaskets and valve guide seals at least.
Sent from my SM-G960U using Tapatalk
