302fix
- Aug 17, 2004
- 490
Hello all.
I have a 1970 Bronco with 3 speed manual. 3.5" lift, 302, Sniper EFI, T shift.
Rig has been running great this summer but just started experiencing difficulties trying to take off in first gear and when I am in reverse.
I get significant shudder/wheel hopping and shakes so bad I can even get it rolling. Reverse has the same type inconsistent engagement but not nearly as bad. If I start out in second it is smooth. Once I'm rolling 2nd and 3rd run well, no issues.
Right before all these symptoms appeared there was a day where I couldn't shift at all and ended up disengaging the linkage and moving it manually then hooking the linkage back up.
I suspect that I'm having clutch or transmission lever adjustment issues. Very little play in the clutch from resting position.
I was pretty sure it wasn't driveline related but never did shim my rear end or get longer drive shafts after my 3.5 lift, so recently I did those tasks.
6 degree shims
new drive shafts
I'm thinking of taking a much closer look at linkage adjustments but suspect I am in for a new clutch.
2 kids in college so AX15 will need to wait.
Many thanks for helping me diagnose my next steps. Any suggestion on where to go next are most appreciated.
6 degree shims
new drive shafts
