My 66 is having trouble shifting into 2nd and 3rd, 1st and R are fine. Other posts have referred to difficulty shifting into 1st and R as being linkage adjustment problems. I followed the procedure in the workshop manual. Not sure why it instructs to run the sleeves out 7 turns (bringing the sleeve closer to the end?) but that didn’t help.
It was shifting fine before I recently put in a new wire harness and had to remove the shift lever to remove the dash. Perhaps I missed something putting the shift lever back on the column?
Tony
Tony
