rednck21
Newbie
- Feb 27, 2002
- 3,915
im posting this for a friend. all items are located in LaFollette, TN. post up or pm me and ill put you in contact with him. i dont have pics, and im not sure if he has any. these are copyed from his ad on another forum...
1974-75 EB dana 44, 3.50 gears, stock traction lock, track bar riser, all of the following is new, Super Winch lock outs, rotors, calipers, heavy duty axle joints, brake hoses, steel brake lines, Stone Crusher steering system (over the knuckle), 7 degree poly. C bushings, poly. radius arm bushings, also included is a set of stock radius arms.
asking $600.00
1974-75 EB 9" large bearing, 10" brakes, carrier pressed apart and welded (not tacked), 3.50 gears, new steel brake lines, thrid link bracket welded on the housing, third link.
asking $200.00 with broke drivers axle (one is available for $57.00 delivered)
or asking $300.00 fixed.
35/12.50/15 BFG's, 2 are at's, 2 are mt's all 4 are new, mounted on 15x10's powdercoated black 5 on 5.5 ford
asking $600.00
2001 Explorer upper and lower intakes (almost identical to 1993 cobra intake set), blasted and painted black (look awesome!) with upper plate "5.0 V-8", complete with fuel rails fuel regulator, fuel injectors (yellow top/19 lb.hr.)
Edelbrock 70 mm throttle body w/ egr spacer has idle air bypass installed, needs a TPS sensor to be complete assembly.
C&L 76 mm mass air meter w/ cast alum. elbow, electronic chip, K&N style conical filter (new).
all parts are in perfect shape!
do not want to seperate! you need the whole thing anyway! bolt this on a stock 5.0 and gain at least 35 HP!
asking $600.00
asking $600.00
asking $600.00
asking $600.00
