Duke Nukem
I was able to pick up a '93 Bronco with a tired 5.0. Since the truck has a Speed Density EFI system, the simple think to do would be to drop in a remanufactured 5.0 and call it done. However, my preference would be to use this as an opportunity to upgrade to a 351W.
That said, it should be noted that I live in the state of Kalifornia, where guns and broncos are no longer politically correct. More importantly, I want the vehicle to be CARB compliant so that there are no issues getting it smogged and registered.
So... my question is whether this can be done in a way that isn't overly complicated. Assuming a bone stock 5.8, can this be done by simply swapping out the 5.0 speed density computer for a 5.8 speed density computer? Would I also need to swap out the wiring harness?
Here's what I'm thinking would be needed:
* 5.8 fuel rail
* 5.8 lower (not sure if the 5.0 upper mates to the 5.8 lower)
* 5.8 distributor
* 5.8 speed density ECU
* 5.8 wiring harness? (not sure if I can reuse the 5.0 wiring harness)
* New exhaust
Is it that simple, or am I opening up a can of worms. Alternatively, I can drop in another 302, but it would be a damn shame.
* 5.8 fuel rail
* 5.8 distributor
* New exhaust
