Millercorey
- Mar 15, 2017
- 232
Background - recently rebuilt engine that had been running really well for the last month or two. Guy that dropped in the motor said to make sure to change the oil after 500 miles or a month, and that I should probably just bring it back to him so he could change it and check everything else out while he was at it. Never got around to finding the time to go see him again so I finally just changed it out myself. After I changed it, couldn't get the engine to run again. So here's what I know and what I think:
-put in standard Motorcraft fl1a oil filter and 20-50 oil with 1/2 quart of zinc additive. Everything was added according to instructions
- I don't believe the oil change has anything to do with my issue
-I plan on parking it for the winter and replacing the floor pans, insulating and adding carpet, so I was fiddling with the auxiliary tank b/c I expect to pull it soon (tank has never been used or even tested)
-like an idiot I fiddled with the fuel selector valve, and while it turns just fine, I suspect it broke internally and is stuck between tanks
-after the oil change, I went to start it up and it idled for 15 seconds then died. Not super uncommon when cold bc I need to adjust the carb a bit
-after this, I couldn't ever get it to fire up. I assumed the valve was stuck between tanks so I bypassed the valve. Once I did, it fired up for 5 seconds and died. Won't start up now
-brand new fuel pump and has been running just fine up to this point. Noob so I won't be using the right terminology here, but I know the tank needs to vent. The line sucks gas up, and if not vented, the ln pressure builds until the pump can't suck anymore gas. I think that's what's happening but I'm not sure how or why. Any ideas how I caused this and what to do?
