- Mar 20, 2008
- 1,249
Follow my train of thought, is this a derailment or an answer to my problems?
on my'73, with 2.5" lift, I currently have:
** Front pinion pointing down 6 degrees from driveshaft angle. AND
** 0.7 degrees of caster...
This tells me the pinion must go UP, while the knuckles need to go in the opposite direction to pitch the top ball joint "to the rear"
so if I install new 7 degree C-bushings UPSIDE DOWN, this will correct the pinion angle Correct?
Now I can cut the welds at the knuckles-to-tubes and rotate the knuckles 1/8" to get @5 degrees caster....
Rotating 1/8" came from...
Axle tube is 2.75" dia.. this = 8.63" circumference.
8.63"/ 360 (degrees) =0.0239" per degree.
5 x 0.0239 degrees = 11.95 degrees or between 7/64 (0.1094") and 1/8" (0.125")
Thoughts?
Thoughts?
