Bronco is back after a fresh 351w install and in the process of breaking in and road testing working out a few kinks. I made a trip to town and drove about 30 miles on that trip. When I got home and inspected I had ATF from front of main seal to the rear diff. It looked like someone squirted the underneath with a hose. I checked the fluid level and it was down a quart. I suspect when I engaged the motor and did a hard shift from 1st to 2nd thats when it happened otherwise no leaks just easy cruising around.
I filled the fluid and wiped it all down underneath trying to find a leak. I can find no leaks and a bit gun shy to try to engage a hard shift at this point. I am wondering if I have a purge valve issue. I am about 300 miles into the break in and maybe I'll try a hard shift again soon. Any tips appreciated.
