I don't understand you have a vacuum gauge and not a timing light? That purchase was backward, if you ask me. Vacuum can be different depending on camshafts and quality of the internal componets. Plus if you have points then you should check dwell as well. You really need timing light to do it correctly. As said the vacuum gauge is to adjust idle or check the condition of valves and rings. Again if you have a camshaft that makes power above 3,500 rpms you may not get 18 inches at idle.
