If its been 4 or 5 years the latch mechanisms mau just need to be cleaned and relubed. I just went thru this recently. The above mentioned adjustment on the rod going to the exterior door handle may help as well.Fyi I completely referbished the doors about 4-5 years ago all new door handles with latches etc...
Nice job with the pics!
The rod from the outside door handle to the latch has a threaded bottom and can be adjusted tighter by disconnecting it from the latch, screwing it clockwise, then reinstalling. When I was 'remodeling" my Bronco I had the same problem. I just screwed the bottom pin in about 4 times and it took up al the slack in the system. Now the outside handles open the doors almost immediately. I also added a little grease to the plate that the push button rubs against to swing up the rod at the handle.
You should'a seen him in there with that white pencil too, trying to put an arrow in place and making it so nice and straight like that!;D
A real contortion-artist at work!
