Do you have power steering? if so 4-6 degrees is good with more being better. If you have manual steering its lower like 2 degrees but Id use more and do a power steering swap. Unfortunetly broncos came with very little caster and even 6 degree bushings sometimes dont get you where you need to be.
Yes i have power steering and hydo assit. It drive nice before i took it all apart. I forgot to mesure it before i took it all apart. Im building radius arms so thanks for the help
The problem will be, when you get to the ideal caster, 8-9 degrees, your front pinion will be pointing at the ground. Cutting and turning the yokes is the only way to achieve both.
