Dannyboy71
- Feb 23, 2011
- 420
Having some idling issues and motor shutting off after about 10 mins of driving. Still has power to the radio, lights, ect, but just quits no sputtering or acting like its running out of fuel just stops. Then its hard to start back up although it does start again and acts like it doesn't want to idle. Its a 351 with an a9p and new rjm harness, centec body harness and an opti shift controller. When I pull codes I get 15 and a 96. 15 could be from disconnecting the battery correct? and 96 is secondary fuel pump circut somthing . The rjm engine harness has one pink wire that goes to the fuel pump which is connected to positive and negative is grounded to the frame is that right? what should I look at? Any help is appreciated thanks.
