I'm well underway with my rebuild. Stripped down to the point of nearly ready to pull the tub off the frame. It's my BrotherInLaws truck who I'm doing the work for. He's not a gear-head. A lot of my questions about previous work have resulted in many a shoulder shrug.
I assumed it still has stock suspension. And I think it does. But I want to be certain before I calculate the BL and SL configuration I want to go with .
Is there a way to determine if, and how much, suspension lift might be there with a nearly empty truck? No motor (302), trans, interior, cab, dash... Etc. (I should have checked before disassembly)
Currently the top of the axle tubes , to frame measures 8" rear, 9.5" front. Again, with all the heavy weight removed. No rear axle blocks.
Here is what it looked like when I started, with new 30" tires.
so.. does this truck already have a small lift? Or stock?
