bronco std
Hey any of you guys have a ididit tilt steering column? If so do you know what steering wheels mate up to it, and do you know if I need some adapters. I think I will need some adapters, but not sure. ???
This is the first time I have converted over a steering column before, and do not have too much knowledge about the steering components (inside the bronco that is..., the column is bolted into the firewall and steering box and appears to work fine). The stock bronco steering wheel does not fit for it has a tong on the back side that prevents it from sliding down on the top part of the shaft.
I was planning on calling ididit to see what they recommend, but wanted to see if anyone has some experience in this field.
Oh, and I have a manual column, if that matters?
Thanks,
Bronco STD
Thanks,
Bronco STD
