My 69 never had a drivers side aux/front fuel tank. Used to have a passenger side aux tank that I never used and removed because I went to a BC tank. My question is regarding what I believe is the aux fuel tank filler cavity. In front of the drivers side rear wheel well is a piece of factory sheet metal that most likely created the void outside the passenger compartment for the fill tube to reach the tank. If I were to remove that sheet metal piece, would I then have a hole in the floor of the tub? I suspect the answer is yes.
The reason I'm considering removing it is because I wanted to use that spot for future speaker placement. The passenger side is wide open, un-used space there, but the drivers side has the protrusion there. Anyone in the past removed that sheet metal and have any pointers on doing it cleanly?
