Rdubb12
- Sep 12, 2023
- 5
Thanks!They can scan and match the paint color either way. For what it's worth, I rattle canned mine about 5 years ago and still looks perfect.
Unfortunately, you are doing it backwards. Powder is definitely more durable and as long as it is UV stabilized...it will look great for years. But as you have figured out, getting the correct color blend for powder is a time consuming and iterative process. You will need to do several rounds with your powder supplier to get exactly the right color that you want. It is definitely something that can be done, but it requires patience. And of course powder looks different after it is baked.I’m new to the forum and have just purchased a 72. I’ve ordered a family roll cage and curious about paint vs powder coat. I’m thinking it would look best to try and match the paint but I’m not sure if powder coating can match a paint color? Any one have any knowledge here? 72 Bronco
What about painting vs powder?Unfortunately, you are doing it backwards. Powder is definitely more durable and as long as it is UV stabilized...it will look great for years. But as you have figured out, getting the correct color blend for powder is a time consuming and iterative process. You will need to do several rounds with your powder supplier to get exactly the right color that you want. It is definitely something that can be done, but it requires patience. And of course powder looks different after it is baked.
Normally, people will do it the other way. If you can source a powder that is really close to the color that you want...and then you can paint your Bronco to match. Any decent paint supplier can blend a base tint with a computer match to your powder.
If you can't get a perfect match with your powder, then don't try. Nothing looks worse than an "almost matching" paint job.
