- Jan 19, 2004
- 2,175
Posting for a friend-email HIM, his name is Jim
TIA
anyone interested in buying my stock EB width rear standard rotation dana 60? if needed i would remove the 4 link mounts. you would need to weld the spring pads back on. or send me yours and i'll weld them on at what ever angle you want.
it has Detroit locker, 1 1/2 inch, 35 spline, Moser 4130 chromolly axle shafts, (unless you make over 600 HP you will never brake another shaft) large bearing, disc brakes with Ebrake, 5 on 51/2 lug, 4.88 gears, and truss over the center chunk.
it can be bought with a spool or with the locker. i have over $1600 in it. will sell for $900 with locker, $750 with spool, $600 with no locker or spool. gears go with it regardless.
it is a bolt in if you have me weld on leaf spring pads.
i allso have 3 never used, 35 spline, take out Strange Spool's, 4.56 and up gear ratio. $100.00.EA.
TIA
