- Feb 6, 2010
- 532
I'm finally installing a Saginaw style pump on my Bronco to replace the tired and weak Thompson Ford pump. My existing pump's V Belt is driven from the crankshaft and runs the water pump and the power steering pump. The second belt just drives the Alternator, from the crankshaft..
My question is that my current belt is a 17/32 inch wide belt that fits the existing pulleys perfectly. However, my new Saginaw pump's pulley is designed for a 13/32 inch wide belt. I've checked online and do not see any Saginaw style push on pulleys that are designed for wider belts. Are wider ones available or what have others done? I guess I could run a 15/32 inch wide belt and split the difference? My alternator belt is a 13/32 wide one as well. Thanks!
