Airmapper
Foolproofness Tester
Yet another sidetrack to my wiring repair on the '70, my steering column was working fine, but after taking the wheel off to get the dash out I noticed it is in bad shape and "since I have it out" I think I should try to fix it.
It looks like the bearings have seen better days and the teeth the steering wheel presses onto are all mashed down. I found a broken eye bolt in there that was used to replace a missing square head bolt...and part of the main column right up at the top of the tube looks to be repaired with some kind of thin metal (tin can perhaps?) riveted on.
It has all the 3 speed linkage stuff in there, I have no use for that as I have a floor shifter, so if that stuff can go it might make things cleaner.
I have a Grant GT wheel that goes on all this, and after taking one look I have already made a provision for my horn button to go on the dash so I don't have to deal with trying to make that work, as the Grant setup seems to be missing parts for the horn.
What are my options for repairing this setup? I wouldn't consider any of it in "good shape" but several pieces may be reusable.
A used column in good shape to replace it would be cool, I'm trying to keep cost down as much as possible. What years are compatible with the 70? Will all Bronco 3 speed columns work?
Can I remove the shifter components altogether?
Any other suggestions on rebuilding, repairing, replacing stuff?
Thanks for any assistance and please let me know what info I can provide to help, I can get photos if needed.
