Crainbow243
- Aug 7, 2015
- 223
So I am installing a new steering wheel and Adapter from Tom's bronco parts ( https://www.tomsbroncoparts.com/pag.../body/66-77-early-bronco-logo-steering-wheel/ ) and I am having issues getting it to fit/line up.
First issue is that the steering shaft isn't long enough to go through the Adapter plate. I torqued down the thing with the turn signal canceller and horn contacts then fit it up again, but at best the nut grabs a few threads... Anyone else deal with this?
Secondly, when I add the metal cover it rubs on the steering column, I tried loosening the steering column and sliding it in, but can't get any more clearance...
My first thought is grind down the metal cover and the Adapter plate to get more clearance... But I don't want to go that route if there is an easier solution.
Steering column is a 3 on the tree and bronco is a 1975.
Here are some pictures:
