Well
I bought and installed the CURE, which is a Delrin product that takes the place of the boot on the draglink TRE. It has a machined cup to allow for grease to accumulate and hold grease for the TRE.
As the directions stated it said to sand the face of the Cure spacer as this would allow for the TRE pin to seat correctly. (If is was needed) Apparently not all TRE's are the same, some have a long pin and some have a short pin. I tried once, twice and three times before sanding the machined cup down flush with the body of the CURE product. So essentially no place for the grease to be held. Unlike the old TRE boot, there is not way the machined cup on the CURE product was going allow for my TRE to sit down inside the cup as the cup is the same diameter as my TRE.
Installed it and it made a tremendous difference in steering and handling. I think it was money well spent, however I am worried about the fact there is no "cup" left for grease to fill.
Gravel Maker, if your out there please comment.
