MerganserMaster
- Jun 9, 2023
- 42
After working on it for 7 months intermittently, my 1975 302 V8 Bronco now runs and drives. However, I do not know what transmission is in it, other than that the shifter was swapped from a "three on the tree" to a floor shifter (Which I believe has 3 gears + Reverse). I have found two stampings/markings on the gear box and one on the bell housing. This brings me to my next issue, the starter does not fit well on the bell housing and is almost too "long" (despite putting a washer on the bolts to remedy this). My concern is that it will lead to the flywheel wearing out too quickly as it was actually rubbing against the starter (as seen in the photo) before I removed it. Any ideas what the transmission/bell housing are from and how I can fix (or replace) the starter so that it fits correctly? The starter is just a standard, new re-built one for a 1975 Ford Bronco (unfortunately I do not have the original one anymore).
Gear Box Photos:
https://flic.kr/p/2priQCg
https://flic.kr/p/2priR3E
Bell House Photo:
https://flic.kr/p/2prqJUm
Worn Out Starter (I cut a piece off as well so that's why the "top" of it looks werid):
https://flic.kr/p/2prozsv
Gear Box Photos:
Bell House Photo:
