PaveBronco
- Oct 30, 2012
- 912
Anyone installed the explorer 5.0 Saginaw/Delphi pump bracket swap to allow the serpentine belt to be used with a Saginaw pump. I’m scratching my head on the idler pulley install. I’ve got the triangular bracket that attaches to the water pump but for the install of the idler pulley I don’t see how it fits. The instructions say :
Now install the idler pulley onto the bracket. Use original washers and spacers. We provide a 10mm x 65 bolt, nut and lock washer.
Use the .875” spacer and thick washer between the stock idler pulley washer and the bracket. Apply Loktite to the nut.
But the pulley bearing diameter is larger than the supplied bolt and I didn’t have any original washers or spacers, on my original setup.
I’m throwing this out there because I’m old and slow and sure I’m missing something.
