The only kit Wilwood offers that will fit inside of a Ø15" wheel is their Dynapro 6-piston kit with Ø11.75 x .81 rotors, Wilwood #140-13303-**. These kits technically have less thermal mass in the rotors than the standard Ford and GM kits and less caliper piston area, so they require higher operating pressure to produce the same level of brake torque when compared to the GM/Ford kits, assuming similar brake pad coefficients of friction. Due to the aluminum 6-piston calipers, they shed heat more readily and provide better brake pad support, which is good considering the higher average rotor temps in operation.
The larger kits they offer are based on their Forged Narrow Superlite calipers and can be supplied with either Ø12.88 x 1.25 (140-13304-**) or Ø14 x 1.25 (140-13329-**) rotors, corresponding to either an Ø17" or Ø18" minimum wheel diameter respectively. While these kits still have less caliper piston area than the GM or Ford factory disc brake calipers, they have more thermal mass where it counts (and less where it doesn't), decent pad volume and would be an overall increase in brake performance so long as you can supply adequate pressure to them. To maximize performance, doing a similar rear brake swap would be ideal, as that would address the front/back hydraulic balance issue with the front brakes wanting more pressure and the factory rear drums not really being able to handle that. A fixed proportioning valve is just that, fixed, and an adjustable proportioning valve is really only meant for fine tuning, not offsetting major component mismatches.
Tobin
