Nowik35
- Aug 27, 2018
- 195
Gentlemen,
I know there's more threads on here about engines not starting then I want to read, but I figured someone can just pin point my issue. Sooo my rebuilt engine has a whole 25 miles on it maybe. Yesterday I drove it around town for an hour. Ran perfect. I mean starts within a second, ideal very healthy. Ran it at high speed low speed. Started half a dozen times yesterday. All perfect. Took it out this morning. Put the choke on, it turned over but ran VERY rough. And would not stabilize and died before I could fully open the choke. Tried everything, cranked it a dozen times, not even a single fire. Pumped the gas pedal few times and had choke off, and nothing no fire. Walked away out of frustration. Came back few hours later. Checked voltage at coil I get 7v. Tried it several times again, nothing. Spraid carb cleaner in the carb, no difference. Moved the distributor timing a hair, nothing. Moved itt back and it fired up. Idled for about 30sec. I ran to get my timing gun when I came back it died again. Wouldn't turn over again. I ended up killing the battery from all the tries. So I gave it a rest and I'll try something different tomorrow. I need help. I didn't think it's the fuel. I have a clear fuel filter at the carb and I can see fuel in it. Carb is brand new, coil brand new, starter solenoid new. I have NO CLUE why it won't fire up. Any ideas? What are the steps I should take to rule issues out????
