Windshield Fold-Down Latch
HollywoodC
What are people putting on thier hood to allow them to fold down thier windshield and latch it onto thier hood?
I saw Tom's has a Windshield Fold-Down Latch - 3 pc Kit (pictured below).
What else is out there? Pictures of what you have would be awesome. Thanks.
66ALRIDE
Just BIP It!
Dothan, AL
That is all you need in the pictures. The U bolt bolts thru the hood and the windshield rests on it. The pin connects the windshield to the u bolt.
66bronco74
Upland, CA
Hoods for the 66 - 68's had holes drilled for the u shaped latch. Latter Ford stopped installing this early option. It's a lot of wind in your face when driving with the windshield down.
msweb
So the black piece mounts to the outside of the window frame, how do you adjust for tension so the windshield frame doesn't rattle? Any way to do it with a bikini top?
H
HollywoodC
I think I understand, but I need a visual.
How is the black device mounted to the windshield?
Scrapper_MV
Has anyone figured out a way to fold down the windshield with a fiberglass hood? My hood is pretty flimsy (saves weight though) and has a hood bubble in the center that could not support the windshield latch with out some bracing. Has any one done anything like this?
mango
Sarasota, FL
Here is my solution to the folding windshield. Clears the raised hood. Keeps the bimini top on. Rearview mirror stays up. Bugs hurt at 40+mph.
I will get better pics of my simple tie down. It is just 2 small rubber bumpers and an aluminum slot to tie through. The Bronco is not very aerodynamic, and I rarely even tie the windshield down. When going 60+mph, the strap is barely waving in the wind.
Scrapper_MV
That's very cool! But it looks like alot of work. How did you do it?
