Speedway Vintage 16x7 Steel Wheels
fvb100
Has anyone used the Speedway Vintage 16x7 Steel Wheels? Or the 16x8?
They look good and might a be nice upgrade from the stock 15x6 wheels.
Which width would be best for a 265/75R16 (32x10.5) tire on a 2.5" SL and 1" BL?
snoddas
Nice but what about the center bore - big enough for the front hub?
/Anders
fvb100
fvb100
Their 15” 5x5.5 version has 3.6875" center bore.
fvb100
fvb100
But what do you think, 7” or 8” width on 2.5 + 1 inch lift?
71broncman
Woodland Park, Co
I would go with the 7" wheel for the tires you're looking at. If you ever plan on 12.5" wide tires then the 8" would work for both, even though they are a little wide for the 265/75R16's.
Mark.
fvb100
fvb100
Mark.
I was also thinking that until I found the 285/75R16 which is essentially a 33# with 11.3 width. BFG advices minimum of 7.5 rim.
Still in between 32 and 33. Not sure if my rear quarter will handle the 33 without rolling it.
knack
Not sure what sort of driving you plan to do, but I've got a set of 235/85 X 16 Pirelli MT's and a set of 9-32 X 16 Super Swampers, both on 16 X 7 rims. Really happy with both. I use the Swampers for off road excursions only. Really rough on the road. The Pirelli's are great all-around tires, but noisy for some.
Same body and suspension lift as your truck. Both sets of tires measure at about 32" tall. No rubbing. Had some fender rubbing trouble with 33" tires off road. Both of those sets of tires are load range C. Not easy to find in 16" sizes. For me, the D or especially E rated tires are too heavy and stiff for a small vehicle.
fvb100
fvb100
For a lighter 265/75R16 tire you have the Falken or Toyo instead of the heavier BFG KO2.
chrlsful
seen any of the ol Budd 16s?
They look like the rd tractor or 18 wheeler: outties in frnt, innies in back
(all would need 6 or 8 lug unless welded closed/re-drilled).
Pretty sure I saw ol scout (the 80 or 800 models) with them in late '70s
early '80s...
fvb100
fvb100
Won't be able to use these. 4" backspace has appeared not to be enough with the 7" wheel width.
Speedway Motors just confirmed the center bore is 3.6875". That would make it fit he Bronco front hub.
Broncojim
Newbie
I measured the Bronco hub as close to 3.35. That means that the rim would not be centered or supported in any way by the hub but centered only by the acorn nuts on the studs.
Has anyone found concentric rings to fill the gap between the ID of the rim and the hub?
Tuloyuser
Looking to get these, anyone used stock looking hubcaps on these wheels?
