Gas Pig
- Oct 19, 2005
- 2,778
I have a request for three sets of metal backing plate for door inserts. Before I have my metal fabricator make me only a couple sets... just checking if there anyone else wants to be added into the list?
The backing plates for Roadster door inserts are $125 plus shipping.
These back plates have been used with many different brands of fiberglass inserts so compatibility is not an issue. But if you are looking for the closest reproduction to the OEM’s U13 fiberglass inserts it has to be Bronco Design’s new two piece inserts. I received a set of their prototype door inserts to check out. I have to say Corey and the gang did an amazing job on these! So if you are also needing fiberglass door inserts too... please check out Bronco Design’s new two pieces inserts.
The rare early production ‘66 belly skid plate $150 plus shipping.
These skid plates were found on first couple build months in ‘66 but they actually could be used on any truck. The only thing to watch for is the routing of the exhaust system. Obviously the stock 6 cylinder is the easiest application but their has been other bronco owners who used the belly skid plate on V8 trucks too.
Anyways please post onto this tread to add your name on to the list for either backing and/or belly skid plate. Thanks Jeff
