    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
TN Bronco Parts Super Celebration
Status
Not open for further replies.
ransil
Bronco Parts delivered to the Super Celebration in Townsend TN.
I will be there Thursday late morning thru Saturday.
Parts must be paid for in Full or a deposit paid for them to get loaded ( I have taken too many parts home in the past for no shows).
I will mark sold as they are paid.
listing the post # with the parts is helpful , helps me find and mark them faster.
I will be listed parts as I dig them out , check back often.
PayPal or Venmo
Email to inquire about parts or payment instructions, I take PayPal friends & family or whatever they call it now, if standard PayPal add 3%
when you pay in the notes section, list the parts you are paying for and a cell number, so I can track parts easily.
Email me with questions so the thread is not booger up with lots of replies.
If no price and you see an item in the pictures make offer.
If my descriptions are wrong, let me know what it is.
some electrical stuff we can test when you pickup, I will bring a meter and power probe
full resolution pictures in my google drive, plus extra pics.
https://drive.google.com/drive/folders/1JI-embGsRla7F0v7DPPzf-UDFKf0PVBY?usp=sharing
R
ransil
Rear bench seat out of a 72 Bronco $ sold RM
Blasted and patina Drivers fender , believe its aftermarket feels thin compared to the blue one $20
Pair of Fiberglass Fender Reds, no idea of the MFG I have had these for 25 years so that should narrow it down $40
OEM drivers Fender from a 72 Bronco Blue $100
Door Panel $30
R
ransil
Wiper assemble with or without windshield frame $75
vent Box $30
Hood Prop rod $10
C4 Starter 76 Bronco $sold ( I have a bunch of Bronco starter cores if anyone is interested , they could work )
76 manual Brake spacer $5
76 Manual Brake Rod $5
Oil cooler New $20
Smog pump bracket $25
R
ransil
Carb Air cleaner 10 or 12 inch $1
Dampner off a bronco, seen better days $5
Clutch Bracket assy and hardware, block part is modified for newer block $25
Brake and clutch pedal assy complete, rod not in picture $40
Headlight buckets pair $10
Gas cap ( is that even a bronco Part?) $5
Bolt look important if you can identify it $1
Auto Pedal Brake parts with brake switch $10
Blower Motor from a 72 Bronco $10
Air intake assy $30
R
ransil
Dash Column Bezel with clips $10
Door handle cups pair $5
soft top wiper riser Bracket $15
Wiper finger guard $5
Pair muffler clamps $ sold mw
Pair of handles ( are these bronco parts ? old soft doors maybe) $5
Transfer case detent plate $5
mirror is this one of them ultra rare 66 Bronco mirrors?
Solenoid 1 $5
Solenoid 2 $5
R
ransil
Clutch Z bracket $5
Gas Tank switch valve missing knob $10
Light switch OEM bronco used $ sold aj
Column mounted reverse switch 3 speed 72 Bronco $10
Under dash light $5
Emission thingy 72 Bronco ( ???) $ 10
Shock bolt ( I have used these to repair sheared off rear shock mounts) $1
Arm rests rough ( 2 pair) $5 pair
some kind of bracket 72 bronco $5
Fuel lines or vapor lines 72 Bronco $5
Lighter $20
Paper targets $5
R
ransil
Gas cap ( bronco ??) $5
Wiper switch $5
Pair of Lift off hinges $sold RS
Wiper motor $sold DW
Windshield weather strip $5
OEM Fans Volvo or honda cant remember says Denso on them 10 maybe 12" $Sold AW
Radus Arm $20 ea I have a many
Drive shaft $50 ea I have many
Boat wiper motor $1
Inside Door handles OEM Pair $5
R
ransil
Door window crank arm pair $3
C4 access Plate $ sold RS
Leaf spring Hold down plate $10 pair I have many
steering column Bezel bottom half ( not found top yet) $5
Radius Arm Cap $20
Steering Rag Joint 76 Bronco $20
Shift leaver $10
Auto column indicator $10
Turn signal bucket $5
Alternator bracket $5
Heater Cable $5
R
ransil
Dash Knob $3
Mustang Throttle cable $3
Dash bracket $3
72 Wire harness very good shape with IVR $ Sold
some kind of sensor or switch 76 bronco $3
plug / coil wires $1 each
R
ransil
k&N Kit oil is 1/2, cleaner is 1/4 $3
1992 Ford Car Emissions and Schematic books $50
Water proof "pelican" cases 10.18" x 8.55" x 4.78" I have at least 5 $10 ea
link to cases ( made by S3 model 5000)
https://www.leisurepro.com/p-s350bk...dbb0c866f1051b6c7aaaa8068d7df2e2&gclsrc=3p.ds
Water Pump say E9 on it looks new been sitting around for 20 years 1992 mustang most likely $5
Rear seat from 72 bronco $ sold RM
Interstate Battery Electrical manual $1
Texaco Car car books I have 3 189-1992 something like that $1 for all
Old Gates Napa hose and belt books 1990's +/- $1
i'll take 41 for all the books in this above
R
ransil
Pictures from manuals
Texaco car care $2 all 3
Gates,Napa Axion $2
Care bronco Manuals $ 2 each
Interior light $15
Mangler , have top of box and instructions not the bottom with remote $100
R
ransil
Shop Air Filter Regular assembly Google the numbers on each filter for original cost $75
Pair of yellow coiled air hoses , 1 with air gun $10
Duff's Bronco Tin 12" autographed $sold
MEB Bronco's Tin 12" $10 each
swivel cup holders had these dash cross bar $ sold Aw
rope seal installer $ sold AW
Carb tools $ sold aw
Honing tools $ sold aw
FWD axle plugs $2
Window suctions cup ( hold window up) $ sold MW
Wild Horses After burner l tail light cover ( all the cool kids run them)makes nice wall art too. $10
Smooth shift collar $ sold RS
R
ransil
77 Wire Harness very good condition for a Bronco ( see part tag) column wires have bullet connectors on them.$100
Steering column parts $20
Steering Rag joint $20
Bushings energy suspension 9.9107G Bushings, Link, 4-Bar, Polyurethane, Black, 1 1/4 in. O.D., 7/32 in. Flange Length, Universal, Kit - 3 sets $10 ea
main Tank filler rubber hose 12" $5
Hydro boost bracket this was the prototype from the eBay guy, I ran it couple years then MC went bad so I swapped to my old setup , comes with a new Master cylinder $ Sold ED
https://www.ebay.com/itm/Early-Bron...090664?hash=item343f0c9d28:g:JnQAAOSwUn9aSXNH
like this but this one is chevy Astro booster
Side mirror $sold aw
R
ransil
Air intake tube No cracks, not brittle $ sold aw
Fluid Cooler from an explorer or ranger $ sold aw
5.0L Fuel Rails I have 4 $5 ea
there is an adjustable regulator on 1
i has 8 injectors attached
take your pick
10" electric Fan $10
R
ransil
Another Mustang throttle Cable 3rd one I think $3
Bronco Speedo Cable turn freely $ sold AJ
Door hinge with bolts loose $5
Door fling out stopping thing brackets with screws $sold DB
Headlight switch OEM $sold AJ
Knob $3
Crappy looking tach worked when removed $2
EFI Spare Parts Baro Sensor and IGN relays $2 ea
92 Mustang EFI fan with clutch $ sold CW
R
ransil
Steering Shaft $10
C4 Shift Rod $sold
C4 Vacuum hard line goes from motor to tranny $ sold AJ
Oil pickup tube have 2 could be bronco could be Mustang show interest and I'll try to figure it out $10 ea
D44 slugs $5
Grant Steering wheel adapter with screws $ sold DB
J shifter Bottom boot is still pliable, top boot is Ok shifter feel ok not mounted $sold DB
Steering stabilizer bracket $sold DB
R
ransil
Starter Cores $5 each
Tool balancer for having tool overhead used in a production environment this is for heavy tools $20
Stock bump stop pretty good shape for living under a bronco for 50 years $5
92 Mustang EFI Valve covers cast $10
92 Mustang Smog pump $5
92 Mustang power steering pump bracket with 01 super duty dual port ( hydroboost) C2 pump $sold aw
EFI HO upper manifold $10
92 Mustang Fan no clutch $5
R
ransil
Oil pickup mustang or bronco show interest and ill figure it out $10
PS Bracket with Modified for AC delete using the motorsports kit $5
all the chrome silver powered coated front accessories I can bundle, they came off a bronco I put an Explorer kit on.
C4 cover plate #2 $ sold AJ
Alternator or PS bracket $5
Tranny/Tcase mount $20
Ash tray bracket with screw $5
Motor removal Brackets $sold
R
ransil
Superwinch Hub set $40
Reese Towpower 74337 600 Pound Capacity Winch new $15
AIMCO Spring Balancer holds small tools over in a production environment $10 ea I got a bunch
R
ransil
Tire Grooving Knife $40
Dash Black one rough $20
Dash whit one uncut , some patina on back side $60
Disc Brake conversion Hub and Rotor assembly Pair new $180 for both
Brackets to hole gas bottles to wall or what ever you bolt it to $10
Explorer Timing Chain cover $15
C4 Kick down rod $40
Chevy Astro hydro boost short rod 90-92 I think $ Sold ED
Wristed radius Arm, cheap flex for offroad $100
Status
