1966 Lone Rancher
75Denver
Code:
[CODE]
[/CODE]Well, another one found its way into my driveway but only after a long hunt, COVID restrictions and closed down DMV’s, title work issues and delays and finally shipper shortages. I’ve been running through the forum trying to collect as much history while filling in the blanks to an unfamiliar year Bronco (to me). I’ll post this up here for more insight as a collective mind is MUCH greater than mine;D.
This Bronco came out of the CO/NM boarder and was in a terra cotta barn for the last 32yrs. Before that, it was a ranch truck that was ordered with a bill head, full top, and only ONE bucket seat (VIN “698”). I would like to see who has a 66 VIN chart for all the options and if so, a count out here for anyone else that has a “698”. It looks like at one point a second seat was added but it’s hard to say since the vehicle turned into a parts truck over its hibernation. Luckily, it was still very much left intact. Any other cool 66 v8 history oddities are welcome. This was also ordered as a visor delete since there are no holes (just pilot dimples) and special order “D-code” Peacock Blue (thank you Todd Z. and Drew P.!!).
1sicbronconut
Very nice score! It would be interesting to know what the cut off dates were between the early 66' tall shifter and the "T" style that you Bronco has??
okie4570
NW OK
Cool find! Through the thousands of 66 vins I've looked at over the last two years, I've only seen one other "6" driver bucket only, and it's on a u13.
okie4570
NW OK
Sometime around March 66'. Seems like once the 289 became an option, the changes began to appear.
JGbronc
Bronco Maniac
Hytop, Alabama
Super cool find, I love it! Like Bobby said, this makes only the second 6 code I know of.
I guess someone wanted to listen to the optional radio alone!
75Denver
75Denver
Thank you for bringing this up. I was curious if it had been pulled and exchanged but it also seems shorter than others...that could just be an illusion of the boot as opposed to the plastic cover found in later years. Thank you for clarifying okie4570. When were the 8-bolt Warn locking hubs offered and how long did it last? This particular set doesn’t seem to match the brochure images but also, I love never seen any Warn hub that looks like those in the Ford material.
okie4570
NW OK
They're in the 1/66' literature as an option, and I'm not sure I've seen any literature earlier than that. I've never seen any that resemble the pic in literature, they look more like Selectro hubs.
75Denver
75Denver
So this is the only (known) style?
chris-nc
Bronco Apprentice
Awesome looking '66.
As far as though hubs, I have them on my early build '66 (Sept. '65) and was able to rebuild them. Also did a LOT of research and found the these are a fairly rare (from what I was able to figure out) set of Warn M4 Premium locking hubs that were a Ford upgrade available on early ‘59 - ‘66 trucks and Broncos. Ford carried the replacement parts on their own master parts catalog until ‘65, then parts had to be sourced by Warn service centers. There is one o-ring that is a special shape that is the seal between the brass actuator and the outer housing. Here are a few pics from when I did mine.
66broncofan
Southern Colorado
I love the Phil long dealership decal on the tailgate. They are still in businesses here in Colorado. It would be cool to reproduce that. Mine was also a visor delete from the factory. Cant tell from the pics but it also looks like there were no arm rests. It should have dimples for those as well.
75Denver
75Denver
Thank you all for the kind words. It has a lot of character and sadly took too long to get here and cost too much but the hunt was worth it and what I’ve learned in the aftermath has been worth it. Thank you chris-nc for the Warn info!! Great stuff! I’m surprised have smooth they operate still as is. Way better than the stock red cap locking hubs!
66broncofan, do you know which store location was the original Phil Long? I looked them up and wanted to speak with someone at the top. It may be a dead end but it would be a great talk regardless. It had armrests and again, needs a driver side matching door panel…anyone out there have one (or a set) to sell??
66broncofan
Southern Colorado
I doubt that any of the current Phil long Ford locations are original, but probably the oldest is the one located at motor city as its closest to downtown.
gnpenning
Bronco Slave
I noticed that yours doesn't have the windshield loop on the hood and the hood appears original. Do you have a picture of the inside/bottom of hood?
My 66 is the same way and doesn't have the 4 supports. I just assumed the hood had been replaced, after seeing yours I'm now wondering?? Hopefully someone can fill in the blanks.
Nice find.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
Excellent find. And one with some history, at least in the sense that it was in its native habitat, too. I presume by "terracotta" barn you mean adobe barn. Important point for the Southwestern afficianados, Majagro Beanfield Wars and all that.
75Denver
75Denver
I have the hook and unfortunately the pin was left behind:(. I'm trying to regain possession of that but they were all there. Is your hood original?
Nice find.
love it when the original ones are found!
Me too!! They're getting harder and harder to find!
I stand corrected...yes, adobe barn;). I'm going to see if anyone still alive has contact with the original owner to gain more insight as to why it was ordered with such limited options. I think whoever did the order sheet was either a bachelor farmer or just liked to work alone. Good to hear from you. I remember drooling over your Bronco years ago!! I remember seeing desert landscape and maybe even some pics of it near AZ/UT. Great job and awesome adventures.
