I couldn't add to this older thread:
While I'm not a super experienced mechanic, I share my experience in hopes of helping someone else. My Bronco is a 1970, with I believe an October 69 build date.
Before you get started:
Make sure you have a fire extinguisher handy, and an escape path.
Be safe, take your time. This is pretty easy to perform, but you do have to think things through.
Background - after almost 20 years parked, I decided it was time to get my truck running again. Found out that either my 1G, its wiring or the voltage regulator were junk. Knowing I'd need more output later, I decided to tackle the 3G retrofit. Honestly, the install was pretty straight forward, but I did run into a couple of things which I share below.
The alternator was a pull-a-part unit I 've had for a couple of years. Don't remember what it was pulled from, but I did pull a good portion of the wiring harness that goes to the to the "ASI" three connector plug. This was good - I had plenty of the light green with red stripe wire to work with, and saved me from having to buy a connector.
I did do something remarkably smart before I got started - I took the alternator to a parts store to test its operation. There was no cost for the test, and I was assured things were going to work if I did my part correctly.
