Price Drop from $1600.00 to $1200.00
Have a couple of projects that are in the works and it doesn't look like I will get to this anytime soon and it is going to take a lot of work, as the rust has taken over. Floor pans, Door Post, Aprons and Kick Panels are 100% Rusted out....
The truck is sitting on 35x12.5x15 all terrain tires that hold air, with I think are Mickey Thompson Rims. Not sure the type or height of suspension lift but it appears to relatively new and should clean up. It currently also sits on a 3 inch body lift. The Front End is a Dana 44 set up for Drum Brake and the Rear is 9' set up for Drum Brakes, have not check the gear ratio.
I am including in the sale new sheet metal, I have Driver and Passenger Floor Pans, Aprons and Kick Panels, I also think that I have Right and Left Wheel Tubs. PO owner did replace the rocker panels but did a poor job, so you may be able to salvage them.
I also have two front fenders that are in rough shape and the windshield frame which is in good shape that are not show but included. Otherwise for sale is the rolling chassis and tub seen in picture.
The Frame is in good shape, and should clean up nicely with some work.
NC Title/ Vin Tag and Frame Do Match
Let me Know if you are interested
I can be reached by PM or by cell 828-216-5149 Shoot me a text and I will get back with you.
Jim
Jim
